- Joined
- Sep 14, 2008
- Messages
- 24,836
- Reaction score
- 6,078
- Points
- 113
- Location
- Wibbleton
- Website
- www.tuffty.co.uk
The eco mentalists at work have been busy putting together a list of the top ten tips for driving green so I thought I would share their sterling work...
Funniest thing I have read in ages
Where possible drive with the windows up to reduce drag and make your fuel consumption more efficient.
Try not to be in a hurry. Stressed driving can be erratic and is uneconomical. Simply relax and try to enjoy the trip.
Try not to beat the lights. The chances are that if you hit a red light and then try to beat all the following lights, you will rush but miss them anyway. If you drive at a more sedate speed you will usually find that by the time you reach the next light it will have turned green again.
Air conditioning should be limited as it uses more fuel.
Switch off the engine if you think you will stationary for more than two minutes.
Keep your speed down as driving at 50-60 mph means your emissions will be lowest. Driving over 70mph will rapidly increase your emissions. It can cost you up to 25% more in fuel to drive at 70mph compared to 50mph.
Avoid unnecessary revving or idling of the engine as this uses more fuel.
Harsh acceleration and braking can use up to 30% more fuel and can cause increased wear and tear on the vehicle.
Control your speed. Speedlimits are there to be observed, but did you know that travelling at less than 15mph creates the most pollution? As your speed increases up to 60mph, your level of pollution decreases. Travelling over 60mph increases your level of pollution again.
Careful motorway driving will improve safety and traffic flow. The concertina effect caused by one motorist breaking sharply often results in traffic slowing to a near stop due to the delayed reaction of drivers behind. If we try to observe the car three or four ahead and give ourselves some distance from the car in front we can anticipate and judge the necessary speed. When you see a car break up ahead, simply remove your foot off the accelerator. By the time you get close to the car in front the chances are that they will have speeded up. You can almost make yourself responsible for stopping the concertina.
