Parrot CK3000 Evo mic & controller
JimLoskot
Stockport
Just fitting this kit in and not sure where to put the bits.
Think I might put the mic above the hazards switch, not sure where to put the keypad control thingy.
Any suggestions or where have you put yours?
Also I want to wire the speaker-output to the back of the concert II stereo on the phone line in but I'm not sure how to bypass the mute box? do I need a different cable or has everyone just used the mute box?
Mine is in the middle below the vents, this isn't a very good pic but gives you an idea.
Ref the mic, if you take the light cover off you will see the place for the oem Audi mic, (which might even be fitted) I put mine in there, it's totally hidden but much neater.
thanks james.
mine is the ck3000 and only has the thin bar type controller like this
I put the mic in the light fitting when I had a nokia car kit in there but it wasn't very good, was thinking if I put it here it might be a lot clearer.
did you just use the mute box to wire in the speaker output?
My kit came fitted with the car when i bought it.
In general the Nokia kit I had previous was much better than the parrot kit I have now.
962
7K
805
Az
791
700
