Facelift Anyone retrofitted MagRide ?
jrumball
Bedfordshire
Anyone retrofitted MagRide ? Especially on a front wheel drive Car ? Had a bit of a look and finding not a lot online..... lots about removing it though
Usually each corner has a level sensor, of course shocks, depending on implementation may either be a dash button or mmi config option, but yeah its possible.
Although you already have the level sensors in place for your matrix lighting retrofitting MagRide correctly would require you re-coding, re-parameterising and indeed re-wiring most of your vehicles advanced features... everything from your matrix lights through to your pedestrian protection. Massive job that at this moment in time could prolly not be completed without errors... and MagRide cannot be calibrated while related errors exist, so your vehicle would be bouncing around like a clown car. The cherry on the cake would be that you would need everything that references your level sensors to be re-calibrated including your matrix lights which is dealership only due to the equipment needed.
Reactions: NHN, AlS3BE and jrumball
A personal service as always from @DJAlix ...... :thumbs up:
Well that answers that question , someone on here is selling MagRide shocks and springs for a reasonable price so was curious to what it would take ........
Would I have these problems if I just swapped the springs for Eibach ProLines ? To try and stiffen the ride up .....
Reactions: Kondax
zero problems. Changing the springs to something like the eibach’s will change the car for the better, and once calibrated ou wil onset why the vehicle was not like this from the factory.
Does anything need calibrated after lowering on non magride and non matrix car? Thing like normal led headlights.
Edit: sorry, did not read the question correctly, no... only the headlights level needs to be recalibrated or adjusted.
Reactions: AlS3BE
