Brake lights
GeorgieS3
Halifax
Ok guys my break lights are now on perminantly. I went to change the break light switch as I suspect this is the problem with my esp light, but that's a different matter. I found that euro had supplied me with the rong part so I put evrything back together and now my lights are perminantly on. No fault codes either! Not sure what to do and my battery is dying.
Any advice? Cheers
Ok I am going to presume I have broken my brake light switch, I've taken out the brake light fuse and I will pick up the correct part tommorw, hopefully this will solve it!
My advice would be don't buy brake light switches from ECP. Mine failed and I tried two switches from them and neither worked. Got a refund, went to the stealers, sorted!
Thanks for advice, I will ring the stealers in the morning then.
Got the part from audi, fitted it in no time. Problem solved, cheers for the audi part advise bud.
805
877
657
903
