Any advice on the following would be much appreciated. Have a 2015 A6 C7 2.0D ultra had some work done at local garage for mot and brake sensor faulty, all sorted fine. I did have the engine management light on also that I wanted investigating, he found this to be the DPF blocked, he did a regen and light went off, though within a day or so the light had come back on. Mechanic did another scan says its a different fault to before and is showing as fault code P2002, he seems to think it may be the egr cooler (he googled this) he's not an Audi specialist and isn't too keen on doing it though said he'll drop me someones number.
Ive googled the fault code myself and it seems to be egr cooler or the dpf that people have mentioned. Anyone had this fault themselves and managed to sort?
Does anyone know a good Audi specialist round Manchester you've used? Rather avoid main dealer prices!
Theres one close to me in sale but heard mixed things, mate had a Q7 in with them and they took the pee a bit from what I can gather.
One last thing, I see a lot have people seem to have they're own VCDs/Diagnostic kits, am I right in thinking VCDS is just windows based and run via a laptop with usb to special plug into the car? Could I force a regen on the dpf and stuff like that myself then. Don't wanna spend a fortune or get too technical with it but any advice on what's best appreciated.
