Help - ABS light on.
hooley
All,
Got in the car for the last few mornings to be greeted with nothing new.
Go to pull away and the car is fine for the first few meters and then the ABS light comes on and stays on.
Did a scan with the trusty OBD11 scanner and found:
Fault Code: 01276
ABS Hydraulic Pump V64
Not on initially, then comes on when I go over 10mph, and stays on. Tried to clear the code and failed.
This was not a problem until I replaced the Diverter Valve from the yobbo dump valve the kev had put in the car before I got it.
Any suggestions?
Cheers.
Jason:confused:
on my old car the ABS light came on only when i drove it a couple of metres, Was the ABS wheel sensor.
759
12
colicabcadam
C
877
I
934
imported_Beanflick
I
