My DIY guide for Retro fitting Puddle Lights
NOZ
Firstly please let me apologise if I'm stepping on anybodies toes here
I have come across a hopefully hassle free way to install Audi logo puddle lights, I know from previous comments, threads and forum's, people are wanting to install these but are somewhat put off due to the fact that in some cases it requires making / purchasing looms and then getting pins and connectors coded via vcds ect ect, which may incur a cost unless you know a friend of a friend.....you know what I mean.
But this sounds and is as witnessed working, a much simple way to install these love em or hate em marmite modification. I'm away to get mine fitted on Friday hopefully and pics will follow but here's how a friend of mine has overcome the loom, splicing, and vcds nightmare that has hampered so many people including myself
He has wired them directly into the central locking live and ground wires behind the door panels thus when door is open or unlocked via remote connection is made and logo lights. When vehicle is moving, after a few seconds the central locking auto locks the door and this in turn extinguishes the logo and likewise when you get out of the vehicle and shut the door and remotely lock it the puddle lights are turned off, so you can see is very much a simpler way to install puddle lights.
Im hoping this may prove helpful to people like myself who have had these for s considerable time and as yet have had them installed due to technical or ability issues
Regards Noz
gray99y
I don't think they are hard to wire in, took longer to cut the holes in the bottom of door cards.
slizza786
Active Member
Regards Noz
These?
pipedaudi
I'm not sure how splicing into the central locking wires is any easier than wiring into the correct points on the door module. I could imagine if you wanted to wire it without spending the extra couple of dollars on pre-terminated repair wires. But, why go to all the trouble to get the lights and connectors for the lights, and not get the crimp connection for the module side?
D J Robo
Hi I am new to all this I am trying to fit door warning lights and puddle lights to my Q5 instead of the plastic reflectors I have wired all the lights up connected them to pins 16 front 12 rear does anyone know the codes and procedure to get them to work it is doing my head in : ( many thanks
slizza786
Active Member
Did you get the door puddle/warning lights activated by vcds?
slizza786
Active Member
No i have a mate of a mate who has a vag he said find the codes and he will change the codes over for me
Module 52 and 42 for front passenger and driver door and i believe its +64 to the original value to activate. If its not +64 tell your mate when he opens the coding on each module and clicks on the current value a yellow balloon should pop up and in there it'll tell you the value to add on to activate the lights. Do this to the back doors too on their respective modules.
D J Robo
Hi mate cheers for that so its the same code for Q5 as A4 he said something about needing the long code !!! thank you
RobinA3
Site Sponsor
Site Sponsor
Just for info I am now able to offer a fitting service for my kits so if you are interested in my kits and are a bit worried about fitting please drop me a message.
maxpayne
Hi Guys,
To confirm for 2005 A3 sportback the pins are:
Front -
Pin 18 = Live
Pin 19 = Ground
Rear -
Pin 1 = Live
Pin 2 = Ground.
I had a try at the door card removal earlier and it's a right nightmare. But at least I know how to take it off now...
maxpayne
After playing around it's pin 1 for live on the front passenger door. Haven't checked the other doors yet as I ran out of time!
Hi Guys,
Front -
Pin 18 = Live
Pin 19 = Ground
Rear -
Pin 1 = Live
Pin 2 = Ground.
RobinA3
Site Sponsor
Site Sponsor
Hi Guys,
Front -
Pin 18 = Live
Pin 19 = Ground
Rear -
Pin 1 = Live
Pin 2 = Ground.
Incorrect.
These are only for 2007 onward cars.
All the pin number details are in this thread at the start.
NEALE_WP
Got a cancelled order so have the following available for immediate dispatch.
Front footwell kit - £32.50
Rear footwell kit - £50
Door kits - £36 per door
Postage (special delivery) £10
Prices include loom and lights.
Robin do you still sell the Door kits? I need it dor my 3 Door Audi S3 and can you deliver it to South Africa?
Ownera3
As promised in my post about DIY retro fitting footwell lights (http://www.audi-sport.net/vb/showthread.php?t=58215) here is my guide to fitting puddle lights and warning lights.
I fitted these this morning, took about 6 hrs in total for both doors.
You'll need VAG-COM to switch on the puddle and warning lights, i would advise you to do this first.
You'll need to go to 42 and 52 for the door electrics.
Then in the coding option you'll need to add '64' to the number you already have in the top box, mine was 0000560 so the final number needed was 0000624.
Do this on both 42 and 52.
This the vag com side sorted out.
Now for the hard work.
First of all the doorcards will need to be removed.
Remove the trim.
Undo the 3 screws holding on the door card.
Pull the door card off.
Undo the door handle cable and the electrical cable going to the door controller.
Remove the white foam stuff.
Now you'll need to remove some of the bottom of the door card for the light to sit in place.
I used a drill and used a small drill bit to drill around the rectangle.
Now the light can be palced into the hole, i used a tiny bit of superglue to keep the light in place.
Now for the wiring - DRIVERS SIDE
You can wire the set up in different ways but this is the way i have done it.
Remove the housing from the main connector (GREY).
Now pin 1 is the supply and pin 2 is the earth.
You'll need to get the supply wire to both the puddle light and the warning light.
I used one wire which then split off into 2.
As for the earth this is the way i did it:
Unplug the connector going to the door lock switch.
Undo the clip from the connector by sliding it away.
Remove pin 1.
Replace this wire with another earth wire going from pin one to the earth on the warning light.
The wire which was removed from pin one must now be soldered onto the wire you just put in.
Now you must solder an earth cable going from the puddle light to the earth wire you have just put in.
Put the connector back and plug it back into the locking switch.
Now put the main grey connector back together.
This is what mine looked like when completed.
Put the door card back along with the door handle cable and electrical connector.
The lights should go on when the connector is plugged back in.
Now for the PASSENGER side
The same goes for the passenger side but there is no locking switch to mess with.
As with the drivers door grey plug needs to be taken apart, pin one is the feed and pin 2 is the earth.
Supply the lights with an earth and a supply just like the drivers side.
Remember to tie the wiring down so it doesn't rattle when the doorcard is back on.
Put the door card back on and thats it really.
Here is the end result
If anyone needs any of the correct electrical connectors for the plugs etc then let me know as i have a supply of them.
Hope you find this post useful.
Remove the trim.
Remove pin 1.
I have an Audi A3 sportback 2010 without factory fitted puddle lights. I want to fit a pair of logo lights to just the front doors. Which pins do I use on the 32 pin connector for live and earth connection.
Ownera3
Would this be the correct connector the grey and purple 32 pin
In the drivers door pins with wires are
1,3,5,6,7,8,10,14,15,21,23,24,25,26,31,32
Passenger door 15,21,26
audis3UK
Audi s3 8p 2009 st 2
Hi which pins is it for an s3 8p 2009?
tcardio
Some 2009 models are different. In the US for 2009, in front 18 is empty and 19 is already grounded so you have to splice into. in rear 1 is empty and 2 is grounded so you need to splice into 2. But for 2009 it should be the same 18/19 front and 1/2 rear.
jtraxler1981
So done with the rear on my 06 and in the controller where the pins are empty 1 and 2 I'm still getting nothing. Even after coding with the +64 Still nothing. Havnt done the fronts but I can' imagine that to be the problem.
audis3UK
My pin 18 and 19 on the passenger front door is empty. How do connect a wire?
My car: 2009 s38p3 JAP/AUS.
tcardio
you need to cut the black tie and open up the connector. 18 and 19 are inside. 18 will be free so you plug in power lead from the led into that site. 19 will likely have a brown plug so you cut off the ground connector wire on the led and solder it to the brown wire at 19 site and code the door and you have light
whats going on with that brown wire in your pic at the right lower corner of picture?
audis3UK
The sockets are empty so there is no wire I have to make it stick, what is the name of the lugs I need to buy to make it fit?
samuelh_888
audibhoy11
Right I’m looking to do this, think I might have an easier way but by all means shoot me down if it won’t work
I fitted footwell lights by tapping into the dome light and routing the cables
Now if I tap into that wire again and run a wire through to the door can I not just wire the lights to this extra cable
leonwilliams
Ok good one I did my front footwell I got the loom off ash.and wired into the socket pin 50.
Next I wired led scuff plates I tapped into the dome for the power and earth.
For my rear footwells I made my own loom and I tapped into the led scuff plate lights power . So yes it's doable.
