Where do you access this in vcds? Wouldn't mind having a whirl with this
Wots the benefit in having lower tick over?
They just stretch over time, my car will be going for 2nd cambelt before summer mileage is now at 121,600milesCambelt stretched ? How come has it been replaced before or would this be the first cambelt change?
thought it was every 75? :$ If not i'm well overdueOh right yh that sounds about right mate cambelt every 60K miles, are you running high power through the engine ?
I was sure my mkIV GOLF tdi was @ 50000 and when we bought the A3 a m8 of mine said timing belts should be 75000 or 5years, so I done it at 60000,Oh right yh that sounds about right mate cambelt every 60K miles, are you running high power through the engine ?
car has crturbos stg 2 hybrid on it since oct last yearSo your running hybrid turbo ? What company did you use as ive ordered one from turbo dynamics stage 2, also what turbo have you got on thecar now ?, and the cambelt change is recommended every 75K but i changed mine at 60k aswel just after 5 years old
I have Audi A3 2.0 TDI, 8P, 2012 year. When I start the cold car it is around 800 rpm and then rises to around 1000 and sometimes stays there no matter it becomes warm. Also, when I give throttle it doesn't return to a starting position.
Is this normal?
Here is the video:
