Received my VCDS cable today and have run a scan on the car, the results are below. Dealership have ordered a new air con pressure sensor so should be getting that sorted this week which just leaves the N275 fault if anyone can assist me in understanding the issue.
Chassis Type: 8K (8T0)
Scan: 01 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 52 53 55 56 62
69 72 77
VIN: WAUZZZ8K69A161478 Mileage: 95130km/59111miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAGA) Labels: 03L-906-022-CAG.clb
Part No SW: 03L 906 022 MJ HW: 03L 906 022 B
Component: R4 2,0L EDC H01 4378
Revision: 11H01---
Coding: 0104002C18072820
Shop #: WSC 99999 1023 2097151
ASAM Dataset: EV_ECM20TDI03L906022MJ A01006
ROD: EV_ECM20TDI03L906022B.rod
VCID: 79F9F9FEF818B8D6DC9-802C
1 Fault Found:
5380 - Valve for Air Filter Bypass Flap (N275)
P1016 00 [039] - Open Circuit
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 95139 km
Date: 2014.06.24
Time: 20:22:34
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 AE HW: 8K0 907 379 AE
Component: ESP8 front H04 0240
Revision: -------- Serial number: --------------
Coding: 168500
Shop #: WSC 06335 000 00000
VCID: 7CF7E0EAFF2A8DFEC7F-8029
No fault code found.
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 N HW: 8K0 907 064 N
Component: BCM2 1.1 H80 0143
Revision: 00002001
Coding: 031200
VCID: 3B7523F6BAA44AC68E5-806E
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H36 0041
Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb
Part No SW: 8T0 035 729 N HW: 4E0 035 729
Component: Interfacebox H43 5170
Revision: 00000000 Serial number: 329JY087618710
Coding: 0001002
VCID: 4487580A075A353EFFF-8011
Subsystem 1 - Part No: 8T0 919 609
Component: E0380 BedienteilH08 0100
Subsystem 2 - Serial number: 00000000176457
Subsystem 3 - Serial number: 0119.10.080000000100010008ÿ
Subsystem 4 - Serial number: 010008ÿ
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T2 820 043 S HW: 8T2 820 043 S
Component: KLIMA 3 ZONEN H06 0150
Revision: D0000000 Serial number: 01161020081351
Coding: 34040000
VCID: 428B5E12DD4E3B0ECD3-8017
2 Faults Found:
00457 - Control Module for Network (J519)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 3
Mileage: 95139 km
Time Indication: 0
Date: 2014.06.24
Time: 20:22:34
00256 - A/C Pressure/Temperature Sensor (G395)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 3
Mileage: 95139 km
Time Indication: 0
Date: 2014.06.24
Time: 20:22:34
Freeze Frame:
Temperature: 27.0°C
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 C HW: 8K0 907 063 C
Component: BCM1 1.0 H22 0253
Revision: 04022001 Serial number: 00000000146614
Coding: 260050914034AF000001000000001D0D001D270800010141000000
VCID: 2F6D07A67EDCA66632D-807A
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 211008 H05 0070
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
1 Fault Found:
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 3
Mileage: 95139 km
Time Indication: 0
Date: 2014.06.24
Time: 20:22:00
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 8T2 035 110 C HW: 8T2 035 110 C
Component: MP3-Changer H44 0390
Revision: 00044003 Serial number: AUZ5ZBH8635643
Shop #: WSC 00000 000 00000
VCID: 2B5513B68AC4DA461E5-807E
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H27 0410
Serial number: 0038JD1BYRTG
Coding: 30363435363030303030554A3052384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 3C7720EAB7AA4DFE87F-8069
Crash sensor for side airbag; driver side:
Serial number: 6334MSME412615585
Crash sensor for side airbag; passenger side:
Serial number: 6344MSME41244C517
Crash sensor for side airbag; rear driver side:
Serial number: 6352QSME210F311AA
Crash sensor for side airbag; rear passenger side:
Serial number: 6362QSME7E103638K
Crash sensor for front airbag; driver side:
Serial number: 63732SME0A111C0AY
Crash sensor for front airbag; passenger side:
Serial number: 63832SME0A114212L
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H13 0013
Revision: -------- Serial number: 90304HJH0002I
Coding: 000013
VCID: 3D712DEEA4B044F6B01-8068
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 980 B HW: 8K0 920 980 B
Component: KOMBIINSTR. H17 0224
Revision: 00100000 Serial number: 9E3683JA8
Coding: 2F04100002002600010000
VCID: 316901DE68E8B096249-8064
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 P HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0095
Revision: EB500046 Serial number: 4600E08A1485E5
Coding: 000303
VCID: 4E937A221916CF6E59B-801B
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 M
Component: MNS ECE H52 1060
Revision: 00000000 Serial number: 333JY087627292
Shop #: WSC 00860 210 94674
VCID: 3B7523F67AA44AC68E5-806E
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 E HW: 8K0 959 793 E
Component: TSG FA H11 0250
Revision: Serial number: 0000007661282
Coding: 011002204001410001
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0113951088
Coding: 013B062220390440002002
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
Address 47: Sound System (J525) Labels: 8T0-035-223-ASM.clb
Part No SW: 8T0 035 223 AD HW: 8T0 035 223 G
Component: DSP STD H08 0300
Revision: S2600000
Coding: 010101
VCID: 70EFC4DAA362F99E6B7-8025
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 E HW: 8K0 959 792 E
Component: TSG BF H11 0250
Revision: Serial number: 0000007652016
VCID: 4189511ED8482016D49-8014
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 E HW: 8K0 907 801 E
Component: EPB Audi B8 H05 0060
Revision: 00000003 Serial number: 00000000246817
Address 55: Xenon Range Labels: 8K0-907-357.clb
Part No: 8K0 907 357 B
Component: Dynamische LWR H01 0030
Revision: 00000001 Serial number:
Coding: 0000004
Shop #: WSC 06334 000 00000
VCID: 346708CA57FA85BE4FF-8061
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 336J 087609824
Coding: 0000001
VCID: 2E531AA2B9D6AF6E39B-807B
Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb
Part No SW: 4F0 959 795 N HW: 8K0 959 795 C
Component: TSG HL H10 0251
Revision: Serial number: 0000007520969
Coding: 010002204001210001
VCID: 4487580AC75A353EFFF-8011
Address 69: Trailer (J345) Labels: 8K0-907-383.clb
Part No SW: 8K0 907 383 B HW: 8K0 907 383 B
Component: Anhaenger H08 0080
Revision: 1A002002 Serial number: 00000115538458
Coding: 0100000000000000
VCID: 33650BD692F48286565-8066
Address 72: Door, Rear Right (J389) Labels: 4F0-959-795.clb
Component: TSG HR H10 0251
Revision: Serial number: 0000007520988
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 M HW: 4E0 862 335
Component: Handyvorb2 H20 1130
Revision: 00000000 Serial number: 00000005278508
Coding: 0010920
VCID: 2C5710AA8FCADD7E17F-8079
End ---------------------------------------------------------------------
