I upgraded from a 8P0 907 279 A to a 8P0907279P CE.
Most of things worked fine after a second reset of the CE the only thing that did not work was the signal lights on the fender , front and back work fine.
I noticed that they sometimes blink when the light switch is set to 0 and you turn the wheel but I cannot reproduce that at will. It never bothered me so I did not look in to it.
As I now wanted to do the footwell lights and the anti-dazzle mirror I took the whole interior off again and starting laying all the wires and ran in to a problem.
I have LED front footwell with LED's form @Trups and I have the LED cold diagnose disabled in the CE but they still go out with the "fault in circuit" warning. I tried adding a normal bulb and they stay on so it is most likely this but I don't understand why it's still doing the diagnose when the option is enabled.
Has anyone else had similar problems with the signal lights or the footwell ?
Coding in the A module:
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H27 0401
Revision: 00000000 Serial number: 00000000107934
Coding: 01884F008214101E000000000000000000
Shop #: WSC 00000 000 00000
VCID: 3B7E80867AB2B6C0347
New coding in the P module with no LED footwell, I can add that one later today
Part No SW: 8P0 907 279 P HW: 8P0 907 279 P
Component: Bordnetz-SG H63 2904
Revision: 00H63000 Serial number: 00000004681726
Coding: 098857268294109E10000000000000000008FF1F0001122E008000000000
Shop #: WSC 16070 123 104857
VCID: 4A9B06972516DC1614-801E
