Okay, here's a little update. I got the wire clip on, I put the door card back on, turned on the car and I have nothing working on the drivers side switch(window wind up/ mirror movement) before it was just the drivers side window not moving.
I dug out my laptop with VCDS and it said it had an hour battery left, though okay I'll probably get a scan, started the scan near the end it cut out but got the initial results without clearing. I have the laptop on charge now, I'll later clear and rescan. Could it be a fuse?
1 Fault Found:
01331 - Door Control Module; Driver Side (J386)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Mileage: 144789 km
Time Indication: 0
Date: 2024.01.23
Time: 17:09:14
Freeze Frame:
ON
Address 09: Cent. Elect. Labels:. 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000008700068
Coding: 11AC2F07A0141380EF00001C4F00000000084E0564010003002000000000
Shop #: WSC 06314 000 08192
VCID: 489FB4A73BD5DCD14B-801C
Subsystem 1 - Part No: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 06314
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 66
Reset counter: 8
Mileage: 144759 km
Time Indication: 0
Date: 2024.01.20
Time: 19:33:00
Freeze Frame:
OFF
Voltage: 12.35 V
OFF
ON
OFF
OFF
OFF
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K087150898
Coding: ED801F061002020101
Shop #: WSC 06314 000 00000
VCID: 3561CD535C27513920-8060
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 47
Reset counter: 8
Mileage: 144759 km
Time Indication: 0
Date: 2024.01.20
Time: 19:33:19
00470 - Company Comfort Databus in Single Wire
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 30
Reset counter: 48
Mileage: 144952 km
Time Indication: 0
Date: 2024.02.03
Time: 17:26:05
Address 42: Door Elect, Driver
Cannot be reached
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1980200002186D2D8505489AC637
VCID: 4385A38B02F3FF899E-8016
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
1 Fault Found:
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Component: Tuer-SG H03 0060
Coding: 0000564
VCID: 4487A09707FDF8B1A7-8010
3 Faults Found:
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
008 - Implausible Signal - Intermittent
00944 - Heated Exterior Mirror; Passenger Side (Z5)
012 - Electrical Fault in Circuit
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Mileage: 144789 km
Time Indication: 0
Date: 2024.01.23
Time: 17:09:14
Freeze Frame:
ON
Coding: 00056595
Shop #: WSC 06314
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 66
Reset counter: 8
Mileage: 144759 km
Time Indication: 0
Date: 2024.01.20
Time: 19:33:00
Freeze Frame:
OFF
Voltage: 12.35 V
OFF
ON
OFF
OFF
OFF
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 47
Reset counter: 8
Mileage: 144759 km
Time Indication: 0
Date: 2024.01.20
Time: 19:33:19
Freeze Frame:
Fault Priority: 3
Fault Frequency: 30
Reset counter: 48
Mileage: 144952 km
Time Indication: 0
Date: 2024.02.03
Time: 17:26:05
Cannot be reached
1 Fault Found:
Coding: 0000564
3 Faults Found:
