help with codes what next?
pigy
hey,
just scan my A3 dont know what to do next!
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56
VIN: WAUZZZ8P14A006308 Mileage: 115390km/71700miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
Address 01: Engine Labels: Redir Fail!
Part No SW: 06F 906 056 S HW: Hardware No
Component: MED9.5.10 G00 5201
Revision: 00000000 Serial number: AUX7Z0C3FN704D
Coding: 0000072
Shop #: WSC 06435 000 00000
Part No: 06F 907 807 F
Component: NOX 0901270032 002 0409
06F907807F NOX 0901270032 002 0409
1 Fault Found:
16522 - Oxygen (Lambda) Sensor B1 S2: Signal too High
P0138 - 001 - Upper Limit Exceeded
Readiness: 1110 0101
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 D
Component: ESP FRONT MK60 0102
Coding: 0053894
2 Faults Found:
00810 - Sensor 1/2 for Brake Pressure
005 - No or Incorrect Basic Setting / Adaptation
00778 - Steering Angle Sensor (G85)
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 B HW: 8P0 820 043 B
Component: KlimavollautomatH11 0120
1 Fault Found:
01272 - Positioning Motor for Central Flap (V70)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 72
Mileage: 114600 km
Time Indication: 0
Date: 2010.11.29
Time: 12:54:46
Freeze Frame:
Voltage: 12.00 V
Temperature: 8.0°C
(no units): 24.0
(no units): 43.0
Temperature: 0.5°C
First thing to do is clear the codes and run the vehicle again.
Then re-run the scan and see which faults return.
If you get the same ones back then print a copy of the scan and take it to a dealer/independent approved VAG garage for an estimate for repair !
20
537
NHN
