SDS Woes
jon208
I think I've finally got the RNS-E figured out.
Made a start on the SDS today but can't seem to get it to do anything other than control the phone - which is a bit dodgy in it's operation.
It won't control the radio, CD or nav. Have I got some sort of limited functionality SDS?
If that's the case is it possible to upgrade to full functionality and is it a big job?
I assume the car currently has an 07 DVD in it - not sure as the DVD seems to be in anti theft mode at the moment.
Jon
Most of the RNS-E's need the SDS hack to work, have you used the patched firmware?
The mic also need to be wired in correctly. There is a lot of info to be found on Audi Forum
As Khufu said you need to wire the mic in. I have the SDS on my RNS-E (previous owner enabled it) but i still had to fit the wire, wasn't too hard, hardest bit was probably getting the A piller trim off.
Thanks, I strongly suspect that the unit is still on the 07 firmware. The disc won't eject and I think the coding is set to antitheft mode. I'm planning on getting a 2011 disc for it so that should update the firmware (along with coding it so the disc will eject - obviously!)
I'll pay somebody who knows what they're doing to sort the rest out!
& yes I can add this to the work mate :)
:icon_thumright::icon_thumright::icon_thumright:
981
685
19
80
11K
