DIS Warning - Dynamic Headlight Range
V8Guzzler
Nottingham
So, on the way home tonight, the DIS beeped and the faulty DHR icon came on - (didn't know what it was at first, so looked it up in the manual when I got home.) Anyway it stayed on for a few minutes then went off. A mile or so later, it came back on again.
Is this a major issue or an easy fix? Please help
Ta
:s4addict:
I have run a VAG scan last night - and the results are below - module 55 - Xenon range - I am assuming this is what would be faulty?? If so no fault codes found!! Driving to work this morning still faulty, although the warning light comes on and off - but the lights do not self level as I tested them
Any help would be appreciated :) - will perform another scan later today - im baffled!
VAG-COM Version: Release 409.1-S
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01: Engine
Controller: 8E0 910 560
Component: 4.2L V8/5V G 0030
Coding: 0011711
Shop #: WSC 63351
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 8E0 614 517 Q
Component: ABS/ESP allrad 3032
Coding: 04595
Shop #: WSC 06435
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 08: Auto HVAC
Controller: 8E0 820 043 Q
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
No Faults Found
Address 09: Cent. Elect.
Controller: 8E0 907 279 F
Component: int. Lastmodul RDW 0416
Coding: 01011
Shop #: WSC 63351
Skipping Address 15-Airbags
Address 16: Steering wheel
Controller: 8E0 953 549 N
Component: Lenksáulenmodul 0308
Coding: 00041
Shop #: WSC 63351
Address 17: Instruments
Controller: 8E0 920 980 L
Component: KOMBI+WEGFAHRS. RB4 D36
Coding: 01400
Shop #: WSC 00658
WAUZZZ8E43A358411 AUZ6Z0C0013296
No Faults Found
Address 45: Inter. Monitor
Controller:
Note: Excessive Comm Errors
Address 46: Central Conv.
Controller: 8E0 959 433 BC
Component: Komfortgerát TBF 1712
Coding: 06859
Shop #: WSC 00726
1 Fault Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
Address 55: Xenon Range
Controller: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00060
Shop #: WSC 63351
No Faults Found
Address 56: Radio
Controller: 8E0 035 195 P
Component: symphony II NP2 0152
Coding: 01200
Shop #: WSC 00636
No Faults Found
Address 76: Park Assist
Controller: 8Z0 919 283 A
Component: Parkingsyst. A4 RDW D09
Coding: 00104
Shop #: WSC 63351
No Faults Found
End --------------------------------------------------------------------------------------------------
I would start by checking the level sensor on the rear axle maybe if they aren't adjusting at all
Thanks mate.. I've heard there is one on both front and rear axles that could do with a clean and a good squirt of WD... Will check and report back :)
Cleaned front and rear - still showing fault.... Lights not moving - grrrrrrrrrrrrr....
With the ignitiion off, turn the lights all the way around to dipped beam, then start the car: BOTH beam patterns should bounce up and down to calibrate regardless of what the sensors are doing.
I'd say it was unlikely the motors would both go at the same time, so maybe can point you at wherever they have the first shared component (control unit?) that could have failed.
ok, so i took the glovebox off - unplugged the isoblock from the control unit - and plugged it back in - did the test with the ignition and the lights moved from down to up / level.. no warning on the DIS - but that said it didnt come on straight away before, it took a few miles for it to register, but then kept going on and off... guess i will find out tomorrow on a run... fingers crossed
As mentioned is post #5 there are known connection issues with the headlight control unit.
Maybe removing the power has given it a hard reset it needed??
Update: DIS still showing fault - so I went back to the control unit and with the ignition on, unplugged the isoblock from the unit.. the fault cleared, plugged it back in, fault re-appeared, unplugged, fault cleared.. disconnected battery, plugged back in, fault appeared... so I have left the thing unplugged - I can only assume this means the control unit is faulty? Would you agree? - or could it still be the wiring issue? - which I can imagine is a ****** to sort? Also anyone know the part number of this control unit and approx cost?
te: I managed to get a VCDS scan done and these are the results: Tuesday,12,April,2011,15:37:19:26365 VCDS Version: Release 805.1 Address 55: Xenon Range Control Module Part Number: 4Z7 907 357 Component and/or Version: dynamische LWR D09 Software Coding: 00060 Work Shop Code: WSC 63351 1 Fault Found 00776 - Level Control System Sensor; Left Front (G78) 31-10 - Open or Short to Ground - Intermittent ------------------------------------------------------------------------------ Address 03: ABS Brakes Labels: 8E0-614-517.lbl Part No: 8E0 614 517 Q Component: ABS/ESP allrad 3032 Coding: 04595 Shop #: WSC 06435 1 Fault Found 01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30 35-10 - - - Intermittent It would appear fault code 00774 is no longer an issue! So does this mean there is a bad earth from the front sensor to the module??? Also is the other fault code anything to worry about? Thanks
9
640
14
925
