Good evening all.
I put my food down in 2nd earlier and the car went into limp mode. I pulled over and left the car running for a couple of minutes,and then decided to head home.I drove off and it was fine,boosting as normal etc. Stuck Vagcom on when I got back and got the following:
Saturday, 11 June 2011, 18:57:12.
Control Module Part Number: 8N0 906 018 BH
Component and/or Version: 1.8L R4/5VT 0001
Software Coding: 10710
Work Shop Code: WSC 66565
VCID: 78836BE34BDD
Additional Info: WAUZZZ8LX21017253 AUZ7Z0A2027915
4 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16685 - Shareware Version. To Decode all DTCs
P0301 - 35-10 - Please Register/Activate - Intermittent
16687 - Shareware Version. To Decode all DTCs
P0303 - 35-10 - Please Register/Activate - Intermittent
16688 - Cylinder 4: Misfire Detected
P0304 - 35-10 - - - Intermittent
Misfires-a-plenty? I have cleared the codes and they haven't returned after a little 3 mile test,but what would cause this? I have had all new sparkplugs and coilpacks approx 3 months ago,and the car is only used at weekends. It' a BAM engine if it helps.
Also on a slightly different topic,I had a look at block 010, Ignition Timing Angle, which was all over the place when driving,but I seem to remember reading that it shouldn't go above 10BTDC,mine I have seen in the 30's. I don't know what it all means but couldn't someone tell me if this is normal or I need it looking at?
This has prompted me to become one of the registered users of VCDS so I am just waiting for my email from Rosstech now.
VCID: 78836BE34BDD
4 Faults Found:
