sideways steve
Excuse the title !
2001 S3, facelift.
Std Map
Std Induction
N249 Removed
Aftermarket Downpipe and Sport cat
Standard Dump Valve (diverter valve - however have a forge one to replace it with that I removed from my 1.8t A4)
Now my question is this.....
On almost every other car I have owned that has been turbocharged whether standard or modified you have always been able to hear it dumping boost on lift off even when its recirculating like it does on the S3.
On my S3 when I lift off I hear nothing, its silent. You dont even really get much induction noise.
I expected to hear something but it really is quiet, the car seems to be performing as it should, although I feel my boost tails off a bit higher in the rev range but I do have a slight exhaust leak somewhere which could be a factor in this.
I just wondered if other folk running relatively standard S3's are able to hear it dumping on lift off ? Also what is teh stock boost level on the AMK engined S3 ? I have not fitted my bost gauge yet but might get it done at the weekend so would be nice to check it is indeed boosting properly.
I can VCDS log some runs if anyone requires that sort of info but really I just want to check with folk first incase I am just paranoid and this is normal for a stock S3.
2001 S3, facelift.
Std Map
Std Induction
N249 Removed
