My Rather Slow S3 minor modding thread!
alrighty then... i guess ill be ordering them in .. i just cant justify 180$ for the pair from the stealers crazy price 90$ is more like it :p
btw Lorryz when are you thinking of doing your suspension as tbh i paid 1750$ but Seb did a cracking job however east coast suspension where seb told me to go for corner balancing allignment only charge 900$ for a day only
20120922 110302
thats the S3 on Bilstein B14's and a 30mm drop all i need is some rear adjustable tie arms as the camber is ****** 2.15!!!!
tell me what you guys think ? likey or not ?
at first i thought the same.. ill give it a quick check though i can barely fit 2 fingers over the wheel and the arc.. on both ends front and rear... not to mention where im parked is on an angle too.
well guys i finally got around to changing the boost gauge however im unsure of the readings ? was told they should stay at 14InhG not 18 as im looking at even when warm.. however when i first installed it after the car warmed up to 90 it stuck on 14inHg any help would be great.. im hopping it doesn't spell turbo change.
Thats right mate, shouldnt be lower than 18/20, mine when first startd will hover around 14 but then settle to about 20.
thanks ALOT!!!!! mate thank you i got worried and for some reason i couldnt use the search function either to check about the issue so thanks again..
btw is 11psi normal for an un-mapped 210 AMK S3?
No worries mate, yeah, should be 11/12psi.
Sorry Seb, didn't mean to ignore your PM just had a ton of the things recently and also been a bit busy doing stuff to the car... I have the memory of a goldfish :)
no its fine Paul not a problem.. now i have another rather annoying problem...after fitting the PSS's with HR sway bar's.. i have some sort of rattling coming from the rear end just came from Seb at Euro Automotive.. and said everything was tight and the sub frame was tight...
so my dilemma is now that i don't know were the noise is coming from Seb suggested we do the sway bar links.. (which i have) or the rear front and rear rear wishbone bushes... the ARB already has new bushes fitted
the noise is like a small pebble in a empty cardboard box..ever time i go over uneven surfaces on the road or a tiny bump or hole
anyone has experienced such an issue after fitted new suspension and ARB's ... the front bushes have ALL been changed (powerflex ones) .. i could use some pointers please
well anyways.. small update here.. thanks for the reply Paul as you were the only one =]
some parts on order
KW tie bars - £200.00
Crank Rear Seal - £56.62
Oil Pick up pipe and seal - £9.18 & £3.75
Tie Rods for the front - £115.00
Front and rear ARB links can only get stock ones all 4 - £67.50
ECS Carbon Cover (Main one) - £130.00
Door mouldings lower all - left door £176.58 - right door £176.58
Upper door mouldings for PAS side - £34.85 (door) £16.47 (1/4 panel)
Rear S3 badge - £13.29
Forge Short Shifter - £70.00
Coolant run on pump - £106.53
42draft gear link bushes - £22.00
AwesomeGTI 480ft/lb 6 paddle clutch kit
New gearbox with modified gears, selector forks, and Quaife LSD.. to all the Box to let me break the 300km mark!!
(didnt mean to put the prices but just copy pasted it from an email :p cant be bothered)
hopefully after this replacement, and a new paint job thanks to the incident (i have to fork the money and then claim through courts sadly)... that would pave the way to start building the stocked engine with the stroker kit ive had for a while lol
Damn, I wish my pockets were as deep as yours
Yeah, its unfortunate about that accident, I hope its a quick and painless exercise for you.
lol not really deep but i have no commitments lets just put it that way.. after this stench i cant wait to get it booked and drive im sure im gonna have a big *** smile on me face :D
finally also ordered the bulbs you linked me... just need to add a oil catch can and thats about it till mid december
i think around Christmas we should all have a meet Sydney boys .. dont know how many we are but me you and Sam that i know off :p maybe get abit naughty perhaps (p.s shhhhhhhhhh!)
but the meet cant happen until i get that wagner FMIC and miltek catback :p
