Can someone give this engine picture the once over...
Schlaag
Bwah
Kent
Hi guys, just taken the car out for a test and it is flat as a pancake... im thinking collapsing hose under boost but before i take of this TIP and put it back to standard.. can anyone see anything plugged in wrong / wrong way around that could be my issue?
symptoms are 1st gear picks up great for ..... 4 seconds then everything goes flat.. no power
ive changed the spring in the 008 to a yellow.. no diff... back to std DV.. no difference
air filter taken off so tip has no kink... no difference
help me please :sob:
N75 plumbed in wrong.... the one going into the TIP is where boost should go... the longest outlet on the N75 goes into the TIP
also the pipe to your hockey puck from the TIP is kinked massively too in the pic
Tuffty you are completely right! What a muppet I am. I had so much off the car recently i slipped up on this!
thanks mate.. second pair of eyes always helps!
It is indeed Rob, im going to have to get an aftermarket hose for that... the original is like melted goo.. so crap its unreal!!
will that cause any massive issues in the running of the engine of left like that till the weekend? on to etka as I type!
Sorted. Long n75 pipe to TIP, left side to actuator and bottom to charge pipe
Yeah i had to raid my dads assorted odds and ends to find some pipe to repalce the same hose as mine had about as much strength as a wet paper bag!
