Hi everyone, got a torn cv joint on the inner passenger side on my a4, is this a big job to replace at a garage etc, or is it something i can tackle at home ?. any ideas on cost ?
cheers
Not too bad. But it's easy enough to do on your own. I could unbolt it from the gearbox, push up towards the engine bay and pull out the shaft from the outer drive shaft.
Then work on it on a bench.
