VCDS Log Check - is it running OK
Dan-Jnr
Manchester
Did a 4th gear log today whilst I had my laptop with me.
I understand some of figures but could someone tell me if this log looks OK, should I be worried about anything.
Appreciate the help, or if I need to run more logs with different groups do please let me know.
Group A:'003Group B:'115Group C:'118
Engine SpeedMass Air FlowThrottle Valve AngleIgnitionEngine SpeedEngine LoadBoost PressureBoost PressureEngine SpeedIntake AirBoost PressureBoost Pressure
TIME(G28)Sensor (G70)Timing AngleTIME(G28)(specified)(actual)TIME(G28)Temperature (G42)Control (N75)(actual)
MarkerSTAMP /min g/s % °BTDCSTAMP /min % mbar mbarSTAMP /min°C % mbar
0.3223205.365.100.62236054.915809600.0223602401000
1.21244051.6999.622.51.512520118225013100.922360241001040
2.12268085.1110016.52.432800172.9245018801.822600211001480
3.023040146.5399.67.53.333240191.7255025402.732880191002150
3.933520157.3910094.243640191.7255025403.6333601892.52540
4.843920167.691009.85.144080191.7254024704.5438001891.82540
5.744320175.8610010.56.054440191.7251023605.4442001892.52460
6.654680181.97100126.954800191.7248022506.3546002193.72320
7.565000184.1110012.87.865080191.7247022007.2548802390.22210
8.465320197.5399.218.88.765400190.2250021908.1652402496.52220
9.365600197.4299.6189.675680188253020809.065520261002190
10.275880201.8910019.510.575960177.4255020909.985800271002130
11.186120203.1910019.511.476200172.22540208010.876040301002030
12.086320205.1910020.312.396400168.42550209011.7862403297.62060
12.996520210.5310021.813.36560161.72540217012.6964403395.72080
13.896680206.1999.62114.216720157.92520211013.666403595.32090
14.816840207.8610021.815.126880157.12520209014.568003695.32110
15.717000211.2210022.5167000148.11950203015.4169203895.32120
but it quite a bit short of requested boost? n75 is 100%.. is that n75 duty cycle?
it manages to make 2540mbar at 3640rpm but not at over 5000rpm. maybe a tired turbo
Maybe the request is just being a bit unrelastic, after all if it was just meeting boost then you would not be getting as much out of it as you wanted, this way I guess it's making as much as it can.
