- Joined
- Jun 4, 2011
- Messages
- 1,001
- Reaction score
- 149
- Points
- 63
- Location
- Warham, Norfolk, United Kingdom
Hi, not really clued up with all this stuff.
But after recently getting my mate to replace my top two chain tensioners i thought id run a quick scan with my cheapo scanner (which tends to crash every now and then) and it came up with these two faults:
Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl
Part No SW: 8E0 910 559 Q HW: 8E0 907 559
Component: 3.2l V6 FSI 0020
Revision: --H16--- Serial number:
Coding: 010C0003180F0018
Shop #: WSC 06325 000 00000
VCID: 3B7133DF03F5
2 Faults Found:
012410 - Air Intake System: Flow too Low
P307A - 007 - Short to Ground - Intermittent
000104 - MAP/MAF <-> Throttle Position Correlation
P0068 - 007 - Short to Ground - Intermittent
Readiness: 0000 0000
Ive reset the faults for now. And will run one gain later in the week if the scanner will work. Before anyone says it i do intend to buy the RT kit when ive got £250 spare.
Anyways, question is what are the faults if anyone knows???? I assume they could be old from when the work was carried out
VCID: 3B7133DF03F5
2 Faults Found:
