Had my 2005 2.0tfsi auto scanned yesterday,the fella that scanned it added some possible solutions from rosstech website...any ideas? Cheers
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Control Module Part Number: 8E0 910 115 J HW: 8E0 907 115 C
Component and/or Version: 2.0l R4/4V TFSI 0080
Software Coding: 0104000302070120
Work Shop Code: WSC 00654 210 91809
VCID: 2855D2869BFE1B5EF3D-807D
5 Faults Found:
004506 - Fuel Pressure Sensor (G247)
P119A - 001 - Malfunction - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 170822 km
Time Indication: 0
Freeze Frame:
RPM: 793 /min
Load: 14.5 %
Speed: 0.0 km/h
Temperature: 95.0°C
Temperature: 45.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.970 V
008825 - Leak in Air Intake System
P2279 - 002 - - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 170822 km
Time Indication: 0
Freeze Frame:
RPM: 793 /min
Load: 14.5 %
Speed: 0.0 km/h
Temperature: 95.0°C
Temperature: 45.0°C
Voltage: 13.970 V
Possible Symptoms:
*Malfunction Indicator Lamp (MIL) active
Possible Causes:
*Vacuum Leak
*Intake Manifold Runner Position out of Specification
*Faulty Positive Crankcase Ventilation (PCV) System or Heating Element (N79)
Possible Solutions:
*Check Intake System for Leaks
*Check Intake Manifold Runner
*Check (PCV) System and / or Heating Element if applicable
Special Notes:
*When found in the NAR 2.0T (BPY) check RVUTB: 01-09-03 or 2018919 for updated Crankcase Breather Valve
If the breather valve is faulty, full engine vacuum is typically found when removing the oil cap at idle.
001287 - Idle Control System RPM
P0507 - 001 - Higher than Expected. - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 170822 km
Time Indication: 0
Freeze Frame:
RPM: 903 /min
Load: 14.1 %
Speed: 0.0 km/h
Temperature: 82.0°C
Temperature: 34.0°C
Absolute Pres.: 990.0 mbar
Voltage: 14.097 V
Possible Symptoms:
Possible Causes:
*Throttle Valve Control Module (J338) dirty/faulty
*Wiring/Connector(s) from/to Throttle Valve Control Module (J338)
*Vacuum Leak
Possible Solutions:
*Check Throttle Valve Control Module (J338)
*Check Wiring/Connector(s) from/to Throttle Valve Control Module (J338)
Special Notes:
008583 - Bank 1; System too Lean at Idle
P2187 - 004 - - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 170822 km
Time Indication: 0
Freeze Frame:
RPM: 775 /min
Load: 15.3 %
Speed: 0.0 km/h
Temperature: 84.0°C
Temperature: 55.0°C
Voltage: 13.716 v
Possible Causes:
*Injectors leak/blocked
*Air Intake Leak (after MAF)
*Exhaust Leak
Possible Solutions:
*Check Mass Air Flow Sensor (G70)
*Check Injector(s)
*Check Fuel Pump
*Check Activated Charcoal Filter (EVAP) System Solenoid Valve 1 (N80)
Special Notes;
004688 - Fuel Level too Low
P1250 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 171802 km
Time Indication: 0
Freeze Frame:
RPM: 917 /min
Load: 14.1 %
Speed: 0.0 km/h
Temperature: 82.0°C
Temperature: 34.0°C
Voltage: 14.224 V
Readiness: 0000 0001
5 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 170822 km
Time Indication: 0
Freeze Frame:
RPM: 793 /min
Load: 14.5 %
Speed: 0.0 km/h
Temperature: 95.0°C
Temperature: 45.0°C
Voltage: 13.970 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 170822 km
Time Indication: 0
Freeze Frame:
RPM: 793 /min
Load: 14.5 %
Speed: 0.0 km/h
Temperature: 95.0°C
Temperature: 45.0°C
Voltage: 13.970 V
Possible Symptoms:
Possible Causes:
*Vacuum Leak
Possible Solutions:
Special Notes:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 170822 km
Time Indication: 0
Freeze Frame:
RPM: 903 /min
Load: 14.1 %
Speed: 0.0 km/h
Temperature: 82.0°C
Temperature: 34.0°C
Voltage: 14.097 V
Possible Symptoms:
Possible Causes:
*Vacuum Leak
Possible Solutions:
Special Notes:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 170822 km
Time Indication: 0
Freeze Frame:
RPM: 775 /min
Load: 15.3 %
Speed: 0.0 km/h
Temperature: 84.0°C
Temperature: 55.0°C
Voltage: 13.716 v
Possible Causes:
*Exhaust Leak
Possible Solutions:
*Check Injector(s)
*Check Fuel Pump
Special Notes;
P1250 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 171802 km
Time Indication: 0
Freeze Frame:
RPM: 917 /min
Load: 14.1 %
Speed: 0.0 km/h
Temperature: 82.0°C
Temperature: 34.0°C
Voltage: 14.224 V
