Fault codes
Biddy
Hi guys had my a4 avant fault coded today by a very helpful member of forum couple of codes come up gearbox hydraulic pressure sensor g193 i think and also g201 brake pressure sensor which would be why my esp and abs light come on every know and then can anyone help with these codes
Have you still got the fault codes and entered them into the Rosstech wiki? Failing that, just googling a fault code will often bring up some help.
Entered them in but couldnt find code 193 so stoll not sure wat this code means
G193 is a sensor number not a fault code.
Ok that was all i got so i need to do it again to get code then
You need to find out what the actual fault codes are, typically a 5 digit code.
Ok mate cheers will have to get it done again
4K
B
511
700
633
