Stupid question time
andyherd
Dumbarton, Scotland
Hi folks,
After cleaning my motor the other day I noticed the fuel filler neck area was horribly dirty so I blasted it clean with the pressure washer. However the water was not draining away in the filler neck through the drain point (small white insert).
100 2756
I reckoned its blocked and tried to clear it by pushing the shank of a small drill bit down it but it was solid. I can't get on vagcat at the moment to see the arrangement of the filler neck but was hoping for some useful advice.
Try a can of compressed air with a small nozzle, wedge it in there and blast the crap out.
Poke it :)
Reactions: Darylaas
I assume it's not some sort of blanking plug. The other end of what is likely to be a rubber tube with the outlet under the car somewhere is not the place to poke from as there might be an integral one-way flap fitted. If you can clear the initial crud try some flexible curtian wire and solid wire might damage or puncture the tube walls
Shoot it with a shot gun but make sure you miss the tank because there will be an explosion !
But seriously just get wire hanger it will clean it out same thing happened with mine
Amazing answer!!! like it ......... thats almost topgear thinking!
Reactions: TDI140
Had the same with mine, cleared it with a piece of semi ridgid wire. Overflow comes out the rear wheel arch.
Thanks chaps, will be trying the wire option this weekend. But I've got the shotgun on backup:laugh:
Reactions: TDI140
Make sure the shotgun is sawn off as a normal pump action wont cover the whole area lol
Just a quick update to let anyone with the same problem know the solution. I had a roll of solder wire about 1-2mm thick which I carefully pushed down the drain, I felt a bit resistance at a couple of points so worked it back and forth to clear out the dirt. The water drains out just behind the wheel arch.
Next stupid question whilst I'm here: whilst swapping my front and rear wheels to even out the tyre tread wear I noticed the front hub nuts did not have a cover whereas the rears did, am I missing a couple of front covers?
Front
100 2769
Rear
100 2770
15
784
NHN
892
