As above please. I've set the analogue one but the digital one randomly doesn't seem to read the correct time. The LCD display is kinda on the way out too, not sure if this would have any bearing on the clock itself though? It's a 99 S3, thanks.
There should be a little button sticking out below it.
Pull it for about 2-3 seconds & the clock / date should flash.
pull again to cycle through each section & twist left or right to set.
