Hill hold assist
johnnevett
Oldham
Hi all
is hill hold assist a retrofit option for the b8?
Is it just a case of installing the right switch and programming?
Is there any guides anywhere to help do this ?
cheers
john
Requires abs module to be compatible.
With vcds, check if its got the option.
Is this just the auto hand brake release when you pull away?
i just thought it was a standard feature?
No, it's a different switch which makes the car hold when stationary once engaged you don't have to keep pressing it like the normal hand brake switch
Reactions: Audi Dynamik
You also need to run wiring from the ABS module in engine bay to the new switch in the centre console.
Even if the option is already there in vcds like mentioned above?
Is there a guide to this wiring if not
cheers
