What wheels will fit my A3 ? Looking for winter wheels
@udi A3
Well-Known Member
Hull, UK
Website
www.immotec.co.uk
As above, is there a list of compatible wheels from other cars that will fit, or a guide to using spacers/hub adapters to fit a later a3 wheel with 5x112 pcd?
Im after a set of 17 or 18s ideally with tyres or winter tyres, as my current ones are low and will be my future winter wheels.
if theres a guide ive missed it sorry
I have a set of 17" s3 avus alloys sitting around if you want to make an offer. They have rubber on them and the bolt pattern is 5x100.
If you're going to be using the wheels specifically for winter wheels/tyres, then your best bet is to go for 17s or even 16s (depending if they clear the callipers)
Ive got myself a set of multifitment 18s now, my stock 16s were getting very low so now ill put winter rubber on them and use the 18s which were cheap with tread. Just fancied something different but they do the job!
In answer to your question (even though you are not sorted) I find wheelfitment.net a good site for cross reference on what other makes and model share the same pcd :)
Reactions: @udi A3
910
HP
831
