Lost Key
I
imported_MarkC
Guest
does any one know how much is it is to get a new key programed and if it can be done by a non audi garge or locksmith
thanks
not sure how much it is ( its not cheap) but can only be done by Audi.
this one really needs to be documented in a FAQ.. together with facelift headlight installation, and all those other searchable queries.
do the mods or admin have any plans for improvement of this site, such as the creation and maintenance of more FAQ's?
Found this procedure a long time ago and I stored it as a .txt file on my PC
so I don't remember where I got it from (perhaps from here?) or to which models it applies
Programming
When
key added or replace
system malfunction
How
NOTE: max of 4 keys can be programmed (one at a time).
memory positions of existing keys can be identified using diagnostic equipment
If Diagnostic equipment available:
locate vacant memory position for new key
locate memory position for key to be replaced
carry out programming procedure for this key only
if diagnostic equipment not available: Obtain and reprogram all keys
NOTE: Existing key memory positions will be overwritten
switch ignition ON, Use key not fitted with remote control
Manually lock driver's door using key.
Complete the following within 30 seconds:
Within 5 seconds press unlock button on first key once (programs memory positions 1)
Indicator lamps flash once to indicate signal received.
Wait 5 seconds.
Press unlock button once to confirm programming.
Vehicle unlocks. Program mode deactivated.
Switch ignition OFF. Remove Key.
To program remaining keys into memory positions 2,3 and 4. Carry out the complete procedure below for each key:
Switch ignition ON. Use the key not fitted with remote control.
Within 5 seconds press unlock button at 1 second intervals, as follows:
Twice for memory position 2 (2nd key).
Three times for memory position 3 (3rd key)
Four times for memory position 4 (4th key)
Indicator lamps flash once every time unlock button is pressed to indicate signal is received,
Wait 5 seconds.
Press Unlock button once to confirm programming.
Vehicle unlocks. Programming mode deactivated.
Switch ignition OFF, Remove key.
NOTE: Ignition MUST be switched OFF between each key programming procedure.
Memory erase procedure
When
Lost key fitted with remote control
Incorrect number of keys supplied with vehicle.
Switch ignition ON.
Press unlock button 5 times, at one second intervals.
Indicator Lamp flash once every time unlock button is pressed, to indicate signal is received.
Wait 6 seconds.
Press unlock button once (to confirm erase procedure)
Switch ignition OFF. Remove key from ignition.
Remote control should no longer operate system.
Obtain and program all keys.
822
986
