nice. looks interesting. I too am looking into getting a front and rear camera. with my own driving habits, I am worried the camera might actually work against me tho.
right now I am looking to get a digital gauge in there. I am just amazed on how this car has NO coolant temp. it has a useless boost gauge but no coolant temp. so I'm in t he process of finalizing which gauge I'm going to be happy with.
my top contenders are:
there are pros and cons.
Samsung tablet:
using dash command or obdlink.
pros:
its got a 7inch screen and it looks really nice with a few gauges or as many as you want on there.
the gauges are fully customizable.
it will display everything that the data from the PIDS have. (have tested it and it all works great). basically a huge list of information can be put up. (I really only need 1, water temp. anything else is for fun unless I find something that is useful like transmission temp).
I have mostly everything to make it work now. just need to mount it too look nice. (I have a solution for that already)
the gauges are quick to update while the information flows through to the tablet. making the gauge display look almost real.
I can also use the tablet for other things like google maps or Pandora, plus others that might come up later on.
it got the unit for free from sprint, so its the cheapest to me on my line up. how everyone gets one will vary. lol
cons:
powering it can be a bit tricky. I have not tested how it needs to be powered long term. currently I take it out of the car and charge this every other night but if its on all the time during driving I'm not sure if want to keep charging it.
because of the above issue I prefer a unit that will be self contained for a power source.
therefore I need something that will not be using a battery but can use a DC power source instead.
I don't want to keep taking it out all the time so I leave it in there it can be an attraction for someone to steal it.
I want something that when I turn on the car it will automatically turn on and the same for when I turn off the car. having a tablet requires a bit too much attention.
the initial gauge setup is very time consuming because the gauge is sooooo customizable that it can take hours on each gauge to get it where you want it look like.
scangauge II:
pros:
the size is small. making this an easy to install and look discrete.
it will look like its part of the car.
it is powered by the obd2 port so it will power on and off when I turn on and off the car. self contained for power and automated.
design is great. I can manipulate the casing to get it installed exactly how I want it.
I have a blendmount that I just got and will look awesome with it. I got the blendmount because of the awesome craftsmanship and materials they use. in the end it will look like factory when installed.
cons:
cost is pretty expensive for a small unit. no real sale for it and its the high priced unit out of my lineup. $150
from reviews, it seems to update the information pretty slow on the screen. (if I'm only using it for coolant temp then its fine)
the display isn't attractive, its just an LCD screen with numbers and so there are no animation with it.
it has less displayable information even for a digital gauge. I only see maybe 3 items I would want to display at all times and it displays 4.
ultragauge:
pros:
priced pretty decent. $70
the screen is a bit larger. still only LCD with numbers but it does have a larger display.
power is self contained, which comes from the obd2 port. on and off is also when the car is on and off.
it can display a large amount of types of information. it is limited but the list is pretty long.
it can display quite a few on the screen at one time.
cons:
the controls suck on this. its on the back. which means it cant be installed flat on a surface.
installation will be tricky because of the button placement but if not it would have been easy.
it looks nice but it doesn't have the design architecture that makes it look like it was a factory piece.
reviews says it is a tad slow to update the information from the obd2 port.
