@jungle650
Change the behavior of the DRL’s when indicating (Pulsing indicators) for LED headlamps - normal behaviour is DRL's off :-
1. Select STG 09 (vehicle power)
2. STG Access Permission -> Function 16
3. Enter access code 31347
4. STG adjustment -> function 10
5. Channel (16) Leuchte2SL VLB10 – Lichtfunktion G 2 to “Blinken links Hellpase”, was “Blinken links aktiv”
6. Channel (18) Leuchte2SL VLB10 – Dimmwert GH 2 to “100” -- any number from 0-100 -- default is 10
7. Channel (16) Leuchte3SL VLB21 – Lichtfunktion G 3 to “Blinken rechts Hellpase”, was “Blinken rechts aktiv”
8. Channel (18) Leuchte3SL VLB21 – Dimmwert GH 3 to “100” -- any number from 0-100 -- default is 10
What do you mean normal behaviour is DRL off?
My car bought in Spain does the next thing. When you turn on indicator the DRL goes from 100% to 30% dimming down to see better the amber light.
Except with xenon on, in that case DRL automatically dims to 30% and does not dim any lower with indicators
EDIT: didnt read LED headlamps, sorry
