AJ, just found my notes on this. If you wanna pop over during the week fire me a PM
That's awesome! Ill be there soon!
To retrofit you will need the AUX connection port and the wiring loom that goes back to the rear of the MMI unit as the wiring is different to the AMI. Firmware editing is not needed and the coding can be completed via VCDS:Hello, I would ask if you know if the MMI supports more than 4 audio sources.
Right now I have AMI and I just installed an android computer in the car, but the sound from the android switchboard is only heard on cars that have AUX audio source and in my case it does not come out, I leave the image of my car and the Another identical car, but that does not have AMI:
Mine:
1 option - SD Card
2 option - CD-Rom
3 option - AMI (iPod)
4 option - Bluetooth audio
My friend:
1 option - SD Card
2 option - CD-Rom
3 option - AUX connector (jack)
Looking at this I think the difference is not in the cabling, but in the MMI firmware itself that would have to be modified with VCP. Has anyone enabled the AUX source with AMI installed?
regards!
Has anyone changed (upped) the threshold for the LED All Weather Driving Lights disengaging?
They switch off at 70mph (72mph on cruise).
I have not installed one of these but have removed one in order to install AMI/USB. Pretty simple process as long as you have the correct parts.
09 - Cent Elect > (13)-Driving light and parking light-Allwetterlicht Ausschaltgrenze
Edit: and this is the switch on limit - (12)-Driving light and parking light-Allwetterlicht Einschaltgrenze
I referenced a map of a car with xenon headlights with normal fogs, which is set the same. I thought that might be due to the lack of All weather lights.Both of those values on my car are set to 350km/h factory default lol?
Still switches off at circa 70mph
The all weather lights could be linked to the AFS / Static cornering operating speed thresholds... Try testing the following:
09 - Cent Elect
- (3)-static AFS light-Lower speed threshold
- (4)-static AFS light-Upper speed threshold
That blows that idea out of the water then. I have some PFL maps open on my other screen. Taking another look and will update.My upper limit is set to 32kmh and lower is 0kmh (factory default)
You can only have either Ami or aux connection, but not both. And it will need to be vcd coded. You cab just get an Ami to aux input cable.Hello, I would ask if you know if the MMI supports more than 4 audio sources.
Mine:
1 option - SD Card
2 option - CD-Rom
My friend:
1 option - SD Card
2 option - CD-Rom
regards!
Sent from my SM-N910V using Tapatalk
I did the same initiallyYeah I've searched for 'km/h' in the adaptations doc but nothing really relates to the switch off @ circa 70mph
Fully comparable with all MLB II platform and all the new MQB FL modules. More "memory" for future firmware updates. Not sure if it will be able to tweak control module firmware and permissions yet tho. Also Ross-Tech seem to be placing a 10 VIN number limit on itWhat will that do better Alex ? Wondering if it's going to be worth the upgrade for PFL cars ?
I know it's been a long time but do you happen to know how to turn this on with odb11?Not sure what the threshold is, but yes it seems to be speed related, and it does wait until you get pretty close. Sound only, no graphic without hitting the button.
I have a hunch for making the graphic pop-up... might be this:
STG coding -> Select function 07
Select byte 2
Bit 0 - visual representation Einparkhilfe – activate
I really don't know though. If you want to be the guinea pig and test it, please let me know if it works! On second thought... that bit might already be on... have to go check.
Downloading this actually downloads v17.1.1.2VCDS version 17.1.1 now available.
Watch with your sound turned up. The magic happens at approx 6 seconds:
http://vagcarcoding.com/Video/Audibeat.mp4
Currently trying to see if there is a way to boost the volume...
FL only? Unfortunately yes.Nice! FL only I assume?
Would you happen to know how?It's on the TT as well and can be adjusted for loudness
Please can you PM me details on this? Thanks MattiAJ, just found my notes on this. If you wanna pop over during the week fire me a PM
You would need to find your Leuchte channels which are configured as "Abblendlicht", then change the AB value:Please can you PM me details on this? Thanks Matti
Yup, you would need to find the right side also. The above is just an example as I have found that the same spec cars can be configured differently, so make sure that you find the correct channels.Thanks,
Would I need to repeat this for the right side too?
Any idea what they're set to as standard and what is a safe increase in value please?
Its possible as its how I had my PFL set up Don't think I ever posted the coding but its:@DJAlix
Pardon if I missed this in the hundreds of posts in this thread but is there a way to enable just the DRL (and not both DRL + HID lamp) when I unlock the S3 at night?
There was coding for this with my previous Golf R Mk7 so I gotta believe it's possible for the 8V models as well.
Thx.
Might just be FL cars with normal instruments that do this as my VC sweeps / stages on every ignition acc / terminal 15, foot on brake included.Just activated needle sweep and it took a while before I found out it only works if you don't have your foot on the brake while you turn the key
Don't know if it's supposed to be like this? Or maybe it's just like this on the facelift?
Not a problemLovely thanks. Will have a play and let you know.
On a different subject, have you seen the Start stop memory function that's come to light? I've not been in here for ages so forgive me if I've overlooked it and you've all seen it.
@DJAlix
Thx.
*Before changing these reference the Lasttyp in order to make sure that its configured as "XXX Abblendlicht", example:
- 09 - Cent Elect
- (8)-Leuchte6ABL LC5-Lichtfunktion C 6 = Not Active
- (8)-Leuchte7ABL RB1-Lichtfunktion C 7 = Not Active
- Both channels should be set as the following from the factory: Coming Home oder Leaving Home aktiv
If not then you will need to have a dig around in the other channels in order to find "Coming Home oder Leaving Home aktiv" and then reference the lasttyp etc.
- Leuchte6ABL LC5-Lasttyp 6 = Xenon Abblendlicht (Xenon Headlight)
Also check that the following is set as needed: 09 > Adaptations > Comfort illumination-Coming Home Leuchten.
Thanks @DJAlix ! I'm not so versed on all the VCDS nomenclature but cam follow if the steps are laid out. I also have a 8v PFL so this helps.
Here's the Mk7 Golf Rs steps (with the exception of some distinct DRL features between it and the A3/S3, it matches your instructions):
Sorry try this (I had to separate the https for ot to show here)Cannot see the guide you posted up but if everything seems to match for the most part then you should be good to go. Just remember to make notes so you have something to work from should it all go pear-shaped
