DJAlix
VAG CAR CODING
Site Sponsor
VAG Can Professional
ODIS (Offboard Diagnostic System)
Or the link in this YouTube video
Looks the same to me
Its possible as its how I had my PFL set up Don't think I ever posted the coding but its:
*Before changing these reference the Lasttyp in order to make sure that its configured as "XXX Abblendlicht", example:
- 09 - Cent Elect
- (8)-Leuchte6ABL LC5-Lichtfunktion C 6 = Not Active
- (8)-Leuchte7ABL RB1-Lichtfunktion C 7 = Not Active
- Both channels should be set as the following from the factory: Coming Home oder Leaving Home aktiv
If not then you will need to have a dig around in the other channels in order to find "Coming Home oder Leaving Home aktiv" and then reference the lasttyp etc.
- Leuchte6ABL LC5-Lasttyp 6 = Xenon Abblendlicht (Xenon Headlight)
Also check that the following is set as needed: 09 > Adaptations > Comfort illumination-Coming Home Leuchten.
This is also possible on FL cars as I have seen the coding but I am yet to test due to having no time
- 09 - Cent Elect
- 09 - Cent Elect
Any idea how to make the mirrors unfold on unlock? Mine only unfold once the car has been started, and it drives me nuts!
Have some time today so will have a look in a little bitDigging a little deeper searching my admap for 'coming home oder leaving home aktiv' I may also have to change my parking lights to not active :-
(8)-Leuchte4TFL LB4-Lichtfunktion C 4 (LH PARKING)
(8)-Leuchte5 TFL RB32-Lichtfunktion C 5 (RH PARKING)
Also I found this :-
(4)-Comfort illumination-Coming Home Leuchten (currently set to LOW BEAM)
Great Stuff! I will be testing this on my facelift later today. The matrix lights work a little differently but should be along the same lines.Thanks Alex ;o)
I've just had a play and have it working. To have DRL's only as C/H & L/H lights on a P/F/L S3 with LED headlamps I made the following changes :-
(8)-Leuchte6ABL LC5-Lichtfunktion C 6 -> Not active
(8)-Leuchte7ABL RB1-Lichtfunktion C 7 -> Not active
(4)-Comfort illumination-Coming Home Leuchten -> Fog light
If you cover the rain/light sensor with a rag on the windshield you can test in daylight.
I use an ipad screen removal tool / suction cup thingy to cover the sensors I test
... which is why I ended up doing this lol I got fed up of the wind and also wasting 3m tapeLoL excellent idea there Alex my rag kept blowing off the car !!
Would be awesome if you could mate, this is the last real niggle I have with the car! Oh, and the auto brake drying feature, which I've never been able to disable... do you know if others have had luck using the coding in your doc?Have some time today so will have a look in a little bit
Obdeleven lolhey guys, planning on getting a vcds, and want your opinion which is best? vcds hex net or cable? just for private use. thanks for your answer!
It does have a RLHS and i didnt want to hamper the auto facilities of the actual lights etc.
At the very least would expect DRLS to come on when unlocking. My SQ5 has auto lights but the DRLs come on when locking and unlocking.
Anyone local to Ayrshire area that knows what they're doing be happy to modify a few things for me when I collect my car?
On a PFL in conjunction with the digital speedo no - on a FL yes !
I think it was a MY16 thing as mine will show the time or date
Throwing this one out there before adding it to my PDF as I could use help:
Automatic Rain Closing
09 - Central Electronics
Security Access - 16
Code = 31347
(15) Access Control 2 - Regenschliessen_ein aus = Active (Rain Closing On / Off)
(16) Access Control 2 - Regenschliessen_art = Permanent (Rain Closing Type)
(28) Access Control 2 - Menuesteuerung Regenschliessen = Active (Driver Assist Rain Closing Menu)
Select Long Coding Helper
Select RLFS from Dropdown Menu
Change Long Code to 06A8DD
Testing:
1) Light Switch in Auto position.
2) Wiper stalk in 1st / Auto position.
3) All windows fully open.
4) Locked car and wait for 2 mins.
5) Spray water on windscreen sensor and bam... windows close
Coming Home / Leaving Lights still work as before and without issue.
Comfort Opening and Closing still work as before and without issue.
Auto Lights and Wipers still work as before and without issue.
I do however have the following issues:
1) No matter what I do I cannot get the Rain Closing Menu to display. I tried an MMI reset with the menu + ok + top right selection button's, ignition on / off, nothing. In Fact there are a few menus I cannot seem to activate, including MMI Oil Level and Windows, which is strange as Menu's like Driving School, Exterior Lighting and Wipers (Rain Sensor On and Off) show up as soon as they are coded. Only TPMS needed the MMI reset so far.
2) In addition to having four windows I also have a panoramic sunroof, which does is not auto rain closing. I cannot find any additional channels for this so believe that the option to include the sunroof within "rain closing" is within the MMI Rain Menu.
For those of you with no sunroof, have fun, this works well ...but I was wondering if anyone with Auto Lights and a Sunroof would be willing to assist me with some testing...
As an aside, I will be publishing an updated version of my PDF tomorrow with a good number of new adaptations, including how to change both MMI and DIS Logos
For pre facelift cars no, sunroof is not supported For facelift cars I am yet to test fully but others have reported that its the same situation.Any solution for the sunroof rain closing and for the rain menu on mmi?
I still can only get comfort opening in the MMI screen. I have enabled it all but can't find how to get comfort closing to show up as an option.Can find comfort closing here: http://forums.mwerks.com/showthread...ation-list&p=86597564&viewfull=1#post86597564
And Comfort Closing Confirmation in @DJAlix PDF on page 50.
There isn't an option for closing as a screen on the mmi, just open. Press and hold the lock button in the key and it should close everything up.I still can only get comfort opening in the MMI screen. I have enabled it all but can't find how to get comfort closing to show up as an option.
This is done by activating Engine Data, but I could only activate this via VCP. This is an example display on my own car, non S:On a short test drive video for the 2017 RS3 on Youtube, on the right side of the Virtual Cockpit it shows two readouts for Leistung (power) and Drehmoment (torque).
Is there any way this can be done on the FLS3?
It just looks so cool!!
Don't really work on non S cars tho as its 0 or 100%, nothing meaningful in between. Looks good tho lolThat's well cool Alex !!!!
No annoying paper clip asking "what you want to do today" tho!Ah I see - that's a shame. Quite like the old school Vista/W7 power and memory gadgets too!
Although rain closing works, bar the sunroof, it's never been possible to pop the mmi menu on MMI4G systemsAwww
And how about the Rain Closing Menu on MMI, any solution?
For the most part yes, but there is an adaptation channel to change the "sounder" to the horn. I have never tested this tho:hi guys i have a question about the acoustic alarm on lock/unlock.
is this feature works only if you have the audi anti-theft alarm?
