lewtontric
- Joined
- Feb 10, 2017
- Messages
- 20
- Reaction score
- 4
- Points
- 3
Although rain closing works, bar the sunroof, it's never been possible to pop the mmi menu on MMI4G systems
Okaaay
Anyway, many thanks for all your tutorials
WelcomeOkaaay
Easiest and best quality way to do with is:I've been trying to active phone mirroring on iPhone 6 for ages what exact parts do I need to achieve this.
Vim is already enabled on MMI i have technology pack on RS3 8V any ideas Would be appreciated
iPhone > apple Lightning to HDMI cable > HDMI to RCA convertor box > RCA to AMI Cable > AMI Port
Could also use one of these with an AMI to RCA cable, but the quality is not amazing:
http://www.ebay.co.uk/itm/Car-Mirror-WIFI-Link-Box-for-Android-iOS-Cell-Phones-to-LCD-Monitors-Miracast-/121658152757?hash=item1c53641735:g:7boAAOSwEetV~7wn
I have one of these boxes, used, for sale if interested.
Welcome
There is some thought that changing the Rain Light and humidity sensor from the Audi to a VW one (different part number) will include the sunroof in the feature. I have never tested this tho.
Where did you get the RCA to AMI cable from? Am betting that's your issue...I have all bought all the items listed in the post before it didn't work for me & also another RS3 forum user R55ENS. View attachment 117506
So... engine data and G meter don't work as they should?I got it to show up in less then 3 minutes!! Thanks to you. I used what you said and went into the coding as I was doing the Gforce gauge. You are the man,Thanks !
Doesn't work like it should,I guess thats where the firmware editing comes in. It shows 100% and 0% and looks cool,But needs a signal to be perfect.
I never got around to installing the unit fully, I only used it for testing... wired to fuse 20. You will still need a working / compatable RCA to AMI cable to use it tho. Some of the ones on amazon and eBay are advertised as A3 8V (mmi 4g) but actually don't work with the systems. I used a genuine Audi one.Ok where did you place the unit once it was fitted?
How was the unit to install?
Additional hardware needed for the engine data then, so RS3 feature. Good to know the G Meter is working on the S3. Will investigate the hardware differences.G Force works perfect,I had that done already
RS3 torque / power gauges show 100% and then show 0% and go's back and forth. So I'm assuming it needs some sort of a signal to work like it should.
Is prolly the issue to be honest. Will have a look on eBay for a "good" cable and post the link up.I bought the AMI lead from eBay UK seller i can't find the buyer now it was a while back do you think that may be the issue.
Do you have a link for another AMI cable what hopefully will work
Is kinda VCDS related so not a problem. Am sure others are interested in this subjectOk thank you Alex sorry to fill up the VCDS thread with my posts
Have you seen this thread? I'm going to tackle this myself in the spring.Sorry I have asked this on another thread, I don't seem to find a, how to retrofit the lights under the door for cars without LED interior package.
Does anyone know how to?
Sent from my Nexus 6P using Tapatalk
Where did you get the MMI connector from ?Done it on a members car on here......
Once I'd unlocked VIM for him iphone mirroring worked perfect ......
I will try it later thanks a lot for the replyHave you seen this thread? I'm going to tackle this myself in the spring.
http://www.audi-sport.net/xf/index.php?threads/236949/
You little wizard T-800 proof in the pudding it definitely works then Alex believes it must be my AMI RCA converter which I bought from EBay.
Sorry to be a headache could you find out where that AMI lead was bought from please.
Thank you T-800
The chap bought everything off Amazon
So he was telling me anyway.....
It worked like a charm though even with SD display.
It will do Sorry, been really busy today but will have a look for a good AMI to RCA cable and post up a link in a bit.Ok it must be my AMI lead it worked for you on MMI Low.
I have MMI High hopefully it should work still
@DJAlix
Do you know what these do ? Spent about three hours looking through screens trying to mirror my phone - I didn't change any on these two screen shots below. One has mirror options and one has tv options
I did try adjusting these two below with no luck. I'm wondering if I need to change all of it together ? Such a pita lol
Driving School - I have not been able to activate this on my car but could on my PFL with SD Nav. Basically it puts a digital speedo screen saver on your MMI screen, with turn signal icons.
TV Tuner - As it sounds. This is part of the configuration which needs to be used if you have the OEM TV tuner retrofitted / installed. Audi only option this for the "China" market for some strange reason. Seeing OEM installations outside of China is rare due to the cost of the parts, approx £1000 for used, and not many people know how to complete the install
Mirror - This looks to be related to screen mirroring and is something I will be testing tomorrow. Screen mirroring could mean two things... 1) mirroring of your connected devices screen 2) mirroring the MMI screen to the VC, which is something used in the TTmk3 to mirror the MMI to the VC as there is not center screen.
Not a problemNice,Appreciate the information. I did find a ton of options for enabling driving school but had no idea what it was. I'll mess with that tomorrow sometime. I did find another thing that I couldn't get to work " Dual speedometers " Not sure the purpose of it but it should of worked as I enabled it like I did the gforce meter and RS3 gauges
I tried both options and nothing happened on either my iPhone or android. I was sure that would work. Hopefully you have more luck then me ! Keep us posted
The eBay seller I purchased my lead from is not listing them anymore however he / she is selling this lead, same part number, which should work:It will do Sorry, been really busy today but will have a look for a good AMI to RCA cable and post up a link in a bit.
http://www.ebay.co.uk/itm/New-AUDI-...545678?hash=item1eafafb08e:g:qxQAAOxy4t1Sdoqf
Thank you T-800
@RS3ER
http://www.ebay.co.uk/itm/321424073117 - RCA video converter
http://www.ebay.co.uk/itm/121970082752 - AMI RCA cable
http://www.ebay.co.uk/itm/222331514577 - Phono adaptors
http://www.ebay.co.uk/itm/252727614950 - Genuine Apple Lighting converter (if you have an iphone)
And then just a HDMI 0.5m cable and a micro usb and apple lighting charging cables.
That's all that i bought and with the kind help of @T-800 and @DJAlix we activated VIM
Happy days as now im using my own navigator of my iphone.. and it works brilliant, better that the one i got activated by Audi at £500
Also in stationary waiting in the car parked I have a cheeky look to the football and all TV stuff
Hi lewtontric can I ask if you have a facelift and how you enabled visual parking?
I have a facelift S3 with tech pack advanced but want the display on if anyone knows?
