Dan TheMan Welburn
So i decided to make the long awaited start on my new shocks and springs along with my suspension arms today, and all i can say is what a ****** nightmare! pinch bolt was seized but i expected that, hex end snapped so dragged it through with various nuts and washers etc, then i had issues with drop link so managed to undo one bolt and take full lower arm off as i was replacing it anyway. Then i hit another wall with the track rod end, the locating bolt was corroded solid, ended up cutting track rod end so i could get strut out, unfortunately this left it a bit late to take strut to garage and have the wheel bearing swapped over,
I began to build up new shock and spring onto top mount, there is however a slight downside to these new shocks theres no allen hole in the top to assist tightening the top nut, so im gonna have to get the lend of a windy gun to tighten that before i can fit it, ill also get a butane torch and see if that will help with getting the remaining part of the track rod end off the inner tie rod
so one day in and tbh ive not made nearly as much progress as id hoped, but fingers crossed passenger side wont be as bad, as i dont need to change wheel bearing or track rod end..
