Do you need special tools to do this carbon wrapping?
It is mate, start at one end (I started at the drivers side) gently pull up and out together with your fingers. The first clip should pull out, then work your way across. I didn't use any tools just fingers. As for the wood, good idea I did the same on a jag s type a few years ago, it made it look so much better/youngerI have just had some carbon wrap delivered, I was gonna wrap the plastic/wood colored trim with this, may also do that strip at the back. Is it easy to remove?
Told you it was easy!! Happy days!Did mine last night, it was a doddle, had to lift the first part very carefully with a flat blade screwdriver but it came off reasonably easy. Manged to lose one of the plastic tags but otherwise its all good
Let me know how you get on with the trim pieces will you disc0? Any pics too, I'm interested to know how it turns outDid mine last night, it was a doddle, had to lift the first part very carefully with a flat blade screwdriver but it came off reasonably easy. Manged to lose one of the plastic tags but otherwise its all good
Front or rear?Just in the process at the moment fella, I have completed the back and front door trim and am very happy with the results. I will definitely post up some pics once complete and probably in a different thread.
The ashtray is proving to be a bit of a problem, all the guides I have looked at seem to say just yank it out, now I've pulled pretty hard and it's not moved. I got the gear stick trim off no problem though
Mine on its new hoops :thumbsup:
Instagram: jordcanfield
Fantastic looking car buddy
Nice!!!!! Are we wrapping or painting?
Cheers!!
Grills been Plastidipped and roof bars I had powdercoated in satin black.
Windows trims, I still can't make my mind up. I was thinking wrapping but now I'm thinking the plastidip again. I'm not going to use aerosols this time as I want a totally smooth finish so got a tin, some thinners and will give it a bash with a mini hvlp gun.
The grill looks spot on. I wrapped my boot trim in carbon and now I want my diffuser in carbon to match but wrapping would be close to impossible so I need another option.. where did you get the grill dipped please?
Just did it myself with aerosol Plastidip, did the grill surround on my last A4 with it and it still looks great now. Chrome around the grill is quite easy to do yourself and you don't even have to remove it from the bumper to do it. I like the subtle difference between the dark grey/charcoal of the plastic on the grill and the black of the surround.
Diffuser is actually another project I've got going at the mo, car's going in for a custom exhaust soon so had to get a new diffuser. Picked up a S4 one finished in the standard silvery colour which doesn't really tie in with anything on my car. I've seen pictures of them colour coded and they look ok but fancied doing something different so again I Plastidipped it and I'm actually really liking it, will go well with my red and black theme.
Pics,
Standard S4 silver.
Plastidipped.
And a pic of one colour coded
Pics,
Standard S4 silver.
Plastidipped.
Its a 3.0 V6 isnt it? And yes it is stunning
