cluster swap
Dan21uk
hi all i will explain whats seem to be a problem:
i have 2004 2.0tdi audi a3 and my speedo(actual mph) needle doesnt work
ive used vcds to try all instrumental cluster everything works apart mph needle sits at 0
its siemens vdo.
my question is
can i replace my old with 2nd hand cluster?
can this be from 2009 model(white light up instead of orange one)
can i install diferent make(not siemens)one?
if so how can this be done?
i do have access to a vcds.
thanks for any input!!
can coding be done by myself?my buddy has vag tacho to get skc number
wont work with vag tacho. speak to @udi A3 on the forum he done mine and a few others. highly recommended has all the right tools.
well im based in northern ireland so i would either do it myself or get someone locally to do..
Ouch I see. It's a very complex job and the tools needed are very expensive. Best to see if you can find someone locally. Sorry for not being much help
did any of youse tried to get cluster refurbed?as i take then no coding needed to be done?
ive got 1 lined up for £40 just if its no good to me (needs rewiring) i wont be buying it then..
orher question
if i disable immobiliser could i fit other clocks?
751
557
17
NHN
