rjm180
- Joined
- Mar 28, 2009
- Messages
- 587
- Reaction score
- 36
- Points
- 28
I have recently put 19 inch reps on my S4 cab. They are 8 inch wide and have an offset of 35 and are shod with 245 35 tyres. I actually wanted 8.5's but the supplier ordered what he thought wouldn't rub and not what i asked for, anyway long story and this is what i have ended up with and have been driving for a few months.
I think I would like the rear wheels to stick out a bit further to improve the stance, this prob would have looked better if they were an 8.5.
They also needed spigot rings as the centre bore size was 66 i think and larger than my 57.1.
The front rims and tyres stance look fine so i would like to know, is it ok to use spacers on the rear wheels only. I have read that it is ok to stagger but wanted to make sure on my exact set up. I have also read that ideally a 10mm spacer is a minimum as it is able to locate on the hub, any smaller and they don't, im not 100% sure if this is correct.
If able, I will go for a 10mm spacer on the rears as i think it could take it without having poke.
So basically can i use spacers as well as spigot rings on the rear and is it ok to use on the rear only.
The fronts would be ET 35 and if i use a 10mm spacer this would make the rears have an ET of 45.
Many thanks for your advice,
