Hi guys I want to space my front wheels I currently have 8.5j fronts can I space them by 20mm with out them catching or rubbing etc or do I need to go smaller ?
That is a big spacer for the front and think they will poke out the arch......and would recommend you do something to the rear also otherwise handling will suffer
Sorry I didnt put enough info on the first post the rears are 9.5j with 20mm spacers had to put them on so the wheel didn't catch , so would a 15mm work on the front I.e turning circle and nothing catches
thanks
