Wheel spacers
S23
Torbay
Hi guys I want to space my front wheels I currently have 8.5j fronts can I space them by 20mm with out them catching or rubbing etc or do I need to go smaller ?
That is a big spacer for the front and think they will poke out the arch......and would recommend you do something to the rear also otherwise handling will suffer
20mm will look odd just on the fronts only.. You going stretch look or somethink ?
I used to run 10mm up front and 12mm on the rear, stance was spot on on the Avant
Sorry I didnt put enough info on the first post the rears are 9.5j with 20mm spacers had to put them on so the wheel didn't catch , so would a 15mm work on the front I.e turning circle and nothing catches
11
40
760
816
23
