brasiliangringo
What an utter **** of a job on the TT. I cut the original one out but replacing with a standard pipe was shocking. ELSAWIN as often is pretty ****e and not entirerly accurate.
According to ELSAWIN I had to lower subframe, remove steering rack bolts (4) OS droplink, OS driveshaft and heat shield.
HOWEVER
The steering rack simply doenst drop enough unless you disconnect from the steering column, then with left hand on the OS brake caliper to pull subframe forward i managed to manipulate the downpipe in from the top with right hand. These f'in twats who design these cars.. The more i work with cars the more they **** me off and the newer stuff is even worse, time to change career perhaps lol!!
Anyone else done this - i suspect most peope only replace to fit aftermarket downpipes (cut original out) and new performance ones usually fit much easier (no ridicuould exhaust hanger and are straigher)
HOWEVER
