S3 Fault Code Woes...
goodbuzzman1
A few weeks ago i hit a speed bump....the speed bump shoved my exhaust up, smashing my lambda sensor off the heat shield. It was broken and obviously my engine management light came on.
I went to my local motor factors and bought a universal, wire it up yourself, lambda and installed it. i cleared the fault codes and 1 hour later, the engine light was on again.
I put this down to the lambda i bought not being compatible so i bought a specific NGK Audi S3 lambda and installed it. cleared all codes and sure enough, 1 hour later, engine management light.
The thing is, im getting an array of codes now!!! Could damaging the lambda have done something more serious? shorted something? it snapped at the nut.
Heres my codes now
Address 01: Engine Labels: 06A-906-032-BAM.lbl
Part No: 8N0 906 018 J
Component: 1.8L R4/5VT G 0004
Coding: 10710
Shop #: WSC 33278
VCID: 387513E1180774DE637-5140
WAUZZZ8LX31208933 AUZ7Z0B2170434
7 Faults Found:
17833 - EVAP Purge Valve (N80)
P1425 - 35-00 - Short to Ground
17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2
P1117 - 35-00 - Short to Ground
17861 - Exhaust Gas Temp Sensor 1 (G235)
P1453 - 35-00 - Open or Short to Plus
16486 - Mass Air Flow Sensor (G70)
P0102 - 35-00 - Signal too Low
17523 - Oxygen (Lambda) Sensor Heating: B1 S1
P1115 - 35-00 - Short to Ground
17522 - Oxygen (Lambda) Sensor; B1 S2
P1114 - 35-00 - Internal Resistance too High
17511 - Oxygen (Lambda) Sensor Heating; B1 S1
P1103 - 35-00 - Performance too Low
Readiness: 0010 0101
All those things run from the same +12v feed.
-maf
-egt
-lambda
-evap
If you check for voltage between the blue/yellow wire from any of those components and earth you'll probably find there isn't any, there should be lol.
It'll have blown a fuse in the fusebox on the side of the dashboard, can't tell you which one it is of the top of my head, but it's one of the many listed as 'engine management' on the index card.
-maf
-egt
-lambda
-evap
Thanks for the help.... Although any tips on which fuse to try?
Fuses 29, 32, 34, 37, 43.
It will be one of those.
454
553
508
616
481
