Was under the car at the weekend and noticed a small oil leak coming from the joint of the oil return pipe into the block.
I assume the washer has failed and will need replacing, so would need to remove the pipe......question is, would I need to drain the engine oil off, or could I jack the car into a position to tilt the oil away from that point enought to swap the washer over.
