In the last week I've had two TPMS false alarms, both times the tyres actual pressures were all either spot on or within 1psi of the stored figures.
Could this just be the heat causing a bit of expansion, or is this likely to be a more fundamental fault?
Quite annoying as the first time we were on a long drive and ended up having to divert to two different garages (first one had no air pump) to check, all the while with screaming infants in the back...
