Ok so I've tried searching for an answer on this and looking through the manual but I can't find anything so hopefully somebody will be able to help.
Having decided to play around with the drive select modes today for pretty much the first time since collection day, I noticed that when I change into dynamic mode it goes into sport (ie you can hear the change in engine sound, it holds the revs higher and has an 'S' next to the gear number on the DIS).
Is this normal? I'd though that unless you select sport mode by pulling back on the gear lever then dynamic should just be regular dynamic, not dynamic + sport? Its not really an issue as I keep in in regular dynamic mode all the time and then just select sport when needed, but it just didn't seem right that it was selecting sport as soon as being put into dynamic.
