A4 cab 2003 temp gauge and traction control not working ?
Pete knowles
Age
Worksop
On my Audi A4 cab 2003 I've had it for 3 years now and ever since I've had it the temp gauge and traction control have never worked as the traction light is always on ,on the dash and no matter if u press the button it changes nothing but now and again I'll notice the light go off and my temp gauge workin only for a limited time some times 10 minutes other times a couple of days and the cars seems to run smoother ? What could cause this would it be a Ecu problem ?
Temp guage will be a failed coolant temp sensor. For the traction control fault you'll need to get it plugged into VCDS or a code reader.
But why do they both come on together when the traction control light goes off you can manually turn it off and on and the the temp gauge sits perfectly in the middle ? Surely it's something connected ?
