Temp and Fuel Gauge not working after Clutch and Flywheel change
jvickery
Age
31
Hi Everyone :)
First post here as only had my A4 B6 (1.9 tdi 130ps) a few weeks.
Typically a week after I bought the car the flywheel or clutch started to slip, so I've converted it to a single mass flywheel and put a new clutch in.
Since doing so the Fuel Gauge and Temp gauge on the dash don't seem to be working. The obvious problem would be that maybe we have missed out a sensor or plug when putting it all back together?
Does anyone know if that exists and where I should be looking? Or if it sounds like a bigger problem.
take the battery off for 10 minutes and see if it picks up after this
if not youll need vcds to do some output tests
Great, that fixed the Fuel Gauge issue! Now its just the temperature gauge that isn't working...
Thanks for the help :)
you need vcds to see what the outputs are doing
also check the wiring from doing the clutch
