Lowering springs
freezebox
Does anyone know where I can buy some compatible lowering springs for my 2007 a3 sportback 2.0 tdi quattro s line? I have 18" alloys and would like to eliminate the wheel arch gap.
Would 45mm be adequate? I dont want any tyre rubbing.
Thanks,
You can buy everything you need from @DPM and I can vouch for the service having used them before
40-50mm will be spot on. Remember it's measured from the SE height the s line car is already 20mm lower from factory so another 20-25mm is perfect
Remove arch screw if required but on factory wheels it won't rub
Reactions: DPM and freezebox
474
DPM
21
8K
