After much research and deliberation from looking on the Audizine forums. I decided to finally bite the bullet and do the upgraded s-tronic gear leaver mod....but with a difference, I thought it was too risky to do the heated twist task as I have heard nightmare stories of the plastic snapping or not fitting on right when turned 90 degrees!! I was even advised that if the twist modification is done it may snap over a period of time unexpectedly
My Unit (Stronic) original button hole to the right:
See twist method picture (example) same thing but was on and A3 :
Originally I purchased the whole Stronic (breaking S5) unit and a brand new perforated s-tronic gear stick leaver from the Audi A3 (which looks just as good as the RS leaver ) I had these sitting in my shed for a while as a list of things to do!!
So then last week I had car booked in to do the twist and then the night before the install I woke up in panic, thinking...what if it snaps!!! I wont be able to move / drive the car too risky
So as I decided to get my old one removed and install the complete unit with the lever and stick pointing the correct way.
Feels so much better and looks much better too happy with the finished mod
So as a result here are the pics installed:
BEFORE:
AFTER:
BEFORE:
AFTER:
