Hi
Not sure on your budget mate. I went through this 6 months ago when I bought mine. It had a double din symphony (non-Bose speakers/amp) but I wanted Sat Nav. After reading that the genuine Audi units aren't much copp, I went for this, £240 ish from a UK seller in Liverpool.
http://www.ebay.co.uk/ulk/itm/251514794932
Great looking as it similar to the original Audi unit and has everything you need, DVD, SatNav, Rev Camera etc etc. I got a local recommended fella to fit it and it sounds the nuts, no problems with the amps or sub either. Also, radio reception is fine. The ONLY downside is that when the sat nav is running, there is a bit of a lag sometimes when you press a button or adjust the volume but I've found that if you come away from the map screen temporarily then it's fine.
Dr Evil, once you play about with the equaliser (especially the loudness for the sub) it sounds banging to be fair, I love my bassline!! I'm sure it did slot straight in, you don't need the loom it comes with. Also have a usb cable going into the glovebox to charge my iPhone. You can also play your phones music via the usb or Bluetooth.
Carlcall, the navigation works well but I haven't needed to update it yet as only 6 months old. Quite sure http://www.iceboxauto.com/ supply updates though, which is where I bought it. As I said previously, the ONLY drawback is the lag when you press a button ie adjust the volume when you're using the SatNav. To remedy it, I've found if you come out of the sat nav quickly, press what you've gotta press and go back into the SatNav, it works fine. Hope this helps.
DrStrange, firm I bought it off were UK based and easy to deal with. http://www.iceboxauto.com/
Had a look at ice box auto and they sell quite a few different models. Quite like the look of the A6964 model. http://www.iceboxauto.com/audi-a4s4rs4-2002-2008-android-444-a6964
As in the one I listed? Is it an easy install?I have fitted the same head unit today...pleased for the most part! Will update after a few hours use!
Yep purchased from icebox too.As in the one I listed? Is it an easy install?
great, that's good to know. If I go wrong, do you mind if I pm you!Yep purchased from icebox too.
Install wasn't too difficult - i removed glovebox to run the USB and A pillar to run the GPS. The biggest challenge is fitting the mass of cables behind the headunit after wiring it up - mine isn't perfect so going to redo it. Instructions aren't great, but you can't really go wrong as the connectors only fit in one way!
I have noticed that the plastic is slightly lighter than the audi standard, but it's not too bad!
Got my HU through the post just yesterday so am aiming to install this weekend. Has a pretty basic manual, but nowt on installation. Never changed a HU before so hopefully its straightforward enough.
Any idea if as I have factory fit bluetooth phone - do I have to change the mic etc to the new one or can I leave the old one in place?
Jespy did you run the GPS up the passenger side A pillar?
Yes, went for the one I linked to, going to try and install at the weekend so will let you know.Did you go for the one you posted? I think I'm gonna go for it, let me know how it is please ☺
I had this problem and I was able to get my hand around the back to give it a little extra push......but it was exceptionally tight.
You need something along the lines of this.....a Twin Fakra To Single DIN Aerial Adaptor
Sound ur a half ampHad 30 more mins to muck about so swapped over the HU, wiring was pretty straight forward. Used the single version aerial supplied and it seems to be working fine, CD's fine, Bluetooth phone is fine (haven't had to change the microphone over which was a bonus), sound has been improved.
Need to do GPS and usb cables tomorrow.
Takes a little while to boot up, but not too bad.
One thing that doesn't seem to be right is my rear speakers aren't working. I'm in an estate with stock small amp in the rear which feeds the rear speakers as I understand it. Have I done something wrong or do I need additional connectors, any ideas?
Yep - it's stock set up and non-BOSE so half amp setup in my car as I understand it. Was hoping that it would plug straight in though. Is this a setting issue or wiring?Sound ur a half amp
Is ur 2 front working but nothing rear ?
