D
Deleted member 96254
Guest
With the help of forum guides and YouTube, I have just done my first oil and filter change ever. Well pleased.
My car is a UK registered 2010 A4 2.0 TDi.
I had no previous experience of doing anything mechanical until a couple of days ago so so using a torque wrench is brand new to me!
The position of my oil filter is in a different location to every other guide I have found, towards the back-right of the engine, and sunk about 10 inches.
I took some pictures here:
Pic_1
Pic_2
Pic_3
The oil filter for my car is a cartridge type, part no. 071115562C with a 32mm nut on top.
I removed and replaced the oil without issues, replacing the sump plug at the specified 30nm with my new torque wrench.
However in putting in the new filter, I have not been able to set the torque on the oil filter because it is set at an angle leaning towards the engine.
I can't apply my wrench directly to the nut because the head of the wrench makes contact with the engine. I have tried using an extension bar, but due to the angle cant get a clean connection on the nut because of the pipes pictured getting in the way (pic3).
I have tightened it reasonably tightly with a wrench, but have no idea how tight *25nm is. I tightened is as much as I was comfortable without risking cracking the plastic.
Any advice for next time for a complete amateur would be welcome.
Pic_1
Pic_2
Pic_3
